It is currently Sat Oct 24, 2026 4:36 pm
 Post subject: bypassing my points
PostPosted: Sun Dec 29, 2002 8:16 pm
My '64 dodge dart goes through points like crazy, no clue why. I was thinking about switching to an electronic ignition conversion kit. Has anyone had any success with this??
PostPosted: Mon Dec 30, 2002 7:21 am
Going through points? Is a ballast resistor in the primary circuit?
Now for the answer.
Go with the electronic ignition. You might be able to get an aftermarket system or get one from a salvage yard.
PostPosted: Mon Dec 30, 2002 9:23 am
Car Model: '23 T-bucket
Is it the original distributor.........and does the shaft wobble around in the bushings?
Yes, it would be wise to do the electronic conversion. I'm a cheapskate, so I would be scrounging the salvage yards for usable parts before getting an MP kit.
Roger
PostPosted: Mon Dec 30, 2002 6:57 pm
The capacitor prevents allot of arcing at the points and should be changed along with the points. I remember when I used to run points that a defective capacitor or two came with some cheeper tune up kits I bought. and of course 12v is for starting 6v is for running. A inexpensive volt /ohm meter its great for tracking down all sorts of problems. hope this helps. Bruce Johnson
78b4ramSnortbed/6
Users browsing this forum: Rick Covalt and 11 guests
