It is currently Sat Nov 28, 2026 1:18 am
 Post subject: kickdown on van
PostPosted: Thu Oct 20, 2011 9:44 pm
i have a 84 b150 van with a 2 barrel and 727 ,how do i adjust the kickdown ???
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Thu Oct 20, 2011 10:16 pm
With the throttle fully closed, loosen the nut on the kickdown lever on the transmission until the lever moves freely. Hold the lever all the way forward and the tighten the nut.
PostPosted: Thu Oct 20, 2011 10:28 pm
PostPosted: Tue Nov 15, 2011 8:14 am
forward meaning towards the front ??
PostPosted: Tue Nov 15, 2011 8:41 am
Yes. "Forward" means towards the front, or "fore", of the vehicle, not the rear. To the rear would be "rearward" or "aftward" or "aft." See the "throttle rod adjustment" procedure below.
