It is currently Sat Oct 24, 2026 10:41 am
 Post subject: Oil Pans
PostPosted: Mon Nov 07, 2011 8:29 pm
I know I saw a thread about all the different oil pans there are for the SL6 engines, but I can't ever seem to get the search feature to work the same way twice???
Will this oil pan actually fit my 1964 Dart?
http://www.silver-seal.com/product/TW22 ... l-Pan.htmlImage
Is it as Heavy a gauge metal? or am I better off getting one from the junkyard and refurbishing it? I have a parts car, and the oil pan on it is bashed the same way as my car!
1964 Dart GT
PostPosted: Mon Nov 07, 2011 9:41 pm
6 Pack Dart
See this post
http://www.slantsix.org/forum/viewtopic ... n+pictures
Richard
PostPosted: Tue Nov 08, 2011 12:28 pm
so thats a NO. It looks like the blue one in the old thread? Thanks Richard! I guess it's time to roam the junkyards! I'll hammer out the pan I've got in the meantime.
1964 Dart GT
PostPosted: Tue Nov 08, 2011 8:45 pm
You can use a F-body pan, but it requires modifications. You need to cut the left front corner on the sump and weld in a flat piece of steel, then you need to use a V8 center link or "clearence" the pan at that point.
PostPosted: Thu Nov 10, 2011 7:29 am
Found a good pan(better than the one on my car) at the salvage yard, easy to remove as motor mounts were(1) gone and(1) loose, and the rest of the motor had been picked.
1964 Dart GT
PostPosted: Thu Nov 10, 2011 8:44 am
Love it when that happens. I got a couple rear sump oil pans out of a truck and a van that were easy to pull thanks to previous scroungers. :wink:
Users browsing this forum: DuckDuckGo [Bot] and 10 guests
