It is currently Tue Dec 30, 2025 3:42 am
PostPosted: Sun Nov 13, 2011 2:17 am
Look at what the previous mechanic did (before I took the car)
This is the old carb (Solex) setup ... check out the flange...
He ground and welded the original setup and put the new carb with the flange Fwd-Aft orientation. Original Holley 1920 should be left to right.
Now I have to grind the weld off and see if I can install the 1920 the correct way! Errr...
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Mon Nov 14, 2011 12:24 pm
smh...
"Chrome don't get ya home."
<img src=http://i54.tinypic.com/iznqiu.jpg>
1973 Dodge Dart Custom aka Duh Fart
PostPosted: Tue Nov 15, 2011 5:27 pm
Just makin' sure, the 1920 Holley carb is supposed to be installed directly on the manifold with the supplied gasket only, and not using any gasket sealant. Am I right?
Syed
PostPosted: Tue Nov 15, 2011 5:44 pm
Yes. I can't tell for sure, but it looks like you can unbolt the adapter that was put on the manifold and mount the carb using the factory bolt holes.
PostPosted: Tue Nov 15, 2011 6:05 pm
6 Pack Dart
Reed, he is going to need to cut the weld first.
Richard
PostPosted: Tue Nov 15, 2011 7:35 pm
Oh, I couldn't tell from the pictures where the weld was. Ugh, what a mess.
PostPosted: Wed Nov 16, 2011 12:13 am
Well... at least the intake itself should be re-usable (just thinking positive out of this mess)
Syed
PostPosted: Wed Nov 16, 2011 12:33 pm
What on earth would he have gained by running the Solex? It's like he spent lots of time building a machine that would continually smack him in the head. :lol:
My dad had a 2bbl Solex on his Opel Kadette, it was fritzy & unstable- generally a PIA to work on.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Wed Nov 16, 2011 2:18 pm
sort of like this
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Wed Nov 16, 2011 6:56 pm
sort of like this
hey I WANT that machine LOL
PostPosted: Thu Nov 17, 2011 4:01 am
How about a tightener for a loosener?
PostPosted: Sat Nov 19, 2011 11:39 pm
Managed to chisel out the damn half-head bolt on saturday...
Whats left of the "adapter"
The half-headed bolt :P
The old Solex is now an impromptu ashtray :P
Cleaned the old gasket on the manifold
Walla!! Holley 1920 Installed with the correct kickdown link and started with just 1 crank!
Im a happy papa :)
Syed
PostPosted: Sun Nov 20, 2011 7:16 pm
Is that a (prestolite) direct drive starter?
63 Valiant Wagon
225 - 4 bbl
PostPosted: Sun Nov 20, 2011 8:29 pm
yes it is, used on Pre-'63 US cars I think.
