| Someone tried to be smart and screwed-up my intake manifold https://slantsix.org/forum/viewtopic.php?t=46964 |
| Author: | 1966DartConvertible [ Sun Nov 13, 2011 2:17 am ] |
| Post subject: | Someone tried to be smart and screwed-up my intake manifold |
Look at what the previous mechanic did (before I took the car) This is the old carb (Solex) setup ... check out the flange... ![]() ![]() He ground and welded the original setup and put the new carb with the flange Fwd-Aft orientation. Original Holley 1920 should be left to right. Now I have to grind the weld off and see if I can install the 1920 the correct way! Errr... Syed |
| Author: | Brovender [ Mon Nov 14, 2011 12:24 pm ] |
smh... |
| Author: | 1966DartConvertible [ Tue Nov 15, 2011 5:27 pm ] |
Just makin' sure, the 1920 Holley carb is supposed to be installed directly on the manifold with the supplied gasket only, and not using any gasket sealant. Am I right? Thanks Syed |
| Author: | Reed [ Tue Nov 15, 2011 5:44 pm ] |
Yes. I can't tell for sure, but it looks like you can unbolt the adapter that was put on the manifold and mount the carb using the factory bolt holes. |
| Author: | Fopar [ Tue Nov 15, 2011 6:05 pm ] |
Reed, he is going to need to cut the weld first. Richard |
| Author: | Reed [ Tue Nov 15, 2011 7:35 pm ] |
Oh, I couldn't tell from the pictures where the weld was. Ugh, what a mess. |
| Author: | 1966DartConvertible [ Wed Nov 16, 2011 12:13 am ] |
Quote: Oh, I couldn't tell from the pictures where the weld was. Ugh, what a mess.
Well... at least the intake itself should be re-usable (just thinking positive out of this mess) Syed |
| Author: | WagonsRcool [ Wed Nov 16, 2011 12:33 pm ] |
What on earth would he have gained by running the Solex? It's like he spent lots of time building a machine that would continually smack him in the head. My dad had a 2bbl Solex on his Opel Kadette, it was fritzy & unstable- generally a PIA to work on. |
| Author: | exoJjL [ Wed Nov 16, 2011 2:18 pm ] |
Quote: a machine that would continually smack him in the head.
sort of like this
| Author: | 1966DartConvertible [ Wed Nov 16, 2011 6:56 pm ] |
hey I WANT that machine LOL
| Author: | wjajr [ Thu Nov 17, 2011 4:01 am ] |
How about a tightener for a loosener? |
| Author: | 1966DartConvertible [ Sat Nov 19, 2011 11:39 pm ] |
Managed to chisel out the damn half-head bolt on saturday... ![]() ![]() Whats left of the "adapter" ![]() The half-headed bolt ![]() The old Solex is now an impromptu ashtray ![]() Cleaned the old gasket on the manifold ![]() ![]() Walla!! Holley 1920 Installed with the correct kickdown link and started with just 1 crank! Im a happy papa Syed |
| Author: | WagonsRcool [ Sun Nov 20, 2011 7:16 pm ] |
Is that a (prestolite) direct drive starter? |
| Author: | 1966DartConvertible [ Sun Nov 20, 2011 8:29 pm ] |
Quote: Is that a (prestolite) direct drive starter?
yes it is, used on Pre-'63 US cars I think.
