It is currently Wed Oct 14, 2026 1:05 am
 Post subject: 63 dart headlight part
PostPosted: Sun Nov 13, 2011 8:13 pm
Car Model: 1963 Dodge Dart convertible
My headlight adjusting will not stay in adjustment. I found that the headlight wiring was stuck between the headlamp itself and the bracket (for lack of a better description) that holds the lamp and is used to adjust the beam.
The plastic piece that the headlight beam adjusting screw goes into is cracked because the stuck wire kept the lamp from adjusting correctly.
Anybody know where I might get a replacement plastic piece or the 63 Dart?
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Sun Nov 13, 2011 8:17 pm
I guess the part that is broken is on the headlight mount bucket.
John
PostPosted: Sun Nov 13, 2011 9:24 pm
Can you post a picture for us, showing the part that's broken?
PostPosted: Tue Nov 15, 2011 10:38 pm
I cant get to the headlight now the car is in the garage while I am working on the rear brakes but here is a link to a set of adjusters for a B body.
[url=http://www.megapartsusa.com/proddetail.asp?prod=114%2D280554]
The part I need is the plastic nut that the adjuster screw couples.
Hope that makes sense.
Thanks.
PostPosted: Wed Nov 16, 2011 12:27 am
The nylon piece originally wasn't serviced by the factory so I can't tell you definitively the B-body pieces you found will work in your A-body, but they probably will.
PostPosted: Wed Nov 16, 2011 12:36 am
...you'll definitely find them in a junkyard though.
DORMAN Part # 42189
http://www.rockauto.com/catalog/moreinfo.php?pk=14424
Those it?
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
