It is currently Sat Nov 28, 2026 6:56 pm
PostPosted: Fri Nov 18, 2011 8:04 pm
I have a '71 D100 and would like to swap in a A833OD trans. I have measured the A745 3 speed at approx. 24" overall length. I have been told that the short version of the A833 is around that same length. My question is has anybody done this swap? Should i be looking for a truck or car length trans? I want the install to be as easy as possible so if the current cross member could be used that would be great.
PostPosted: Tue Nov 22, 2011 10:13 am
You want to be looking for the truck length 4 speed OD I just recently swapped from the NP435 to the ODA833 and I am loving it. Basically on the truck version you have a long tail shaft that has a mounting pad near the very back and one near the very front. I know where there is one for sale in my area but the guy wants $300 for it. If you need any help or have questions I am more than happy to give you information on what you need to get everything switched over.
Jeff
jeff_yarbrough@hotmail.com
509-863-2617
PostPosted: Mon Nov 28, 2011 8:21 pm
I am starting the same swap , it looks AS if I am going to have to change my bell housing on my swap and add a crossmember
Dodge =Dam Old Dodge Goes Everywere
PostPosted: Tue Nov 29, 2011 9:21 am
833OD uses a 727 front yoke. Your tranny? I don't know.
PostPosted: Tue Dec 13, 2011 4:16 pm
you will need bell /clutch fork for 833OD m also
