| Want to swap A745 to A833OD https://slantsix.org/forum/viewtopic.php?t=47022 |
| Author: | husker1 [ Fri Nov 18, 2011 8:04 pm ] |
| Post subject: | Want to swap A745 to A833OD |
I have a '71 D100 and would like to swap in a A833OD trans. I have measured the A745 3 speed at approx. 24" overall length. I have been told that the short version of the A833 is around that same length. My question is has anybody done this swap? Should i be looking for a truck or car length trans? I want the install to be as easy as possible so if the current cross member could be used that would be great. Thanks |
| Author: | JeffTheMarine [ Tue Nov 22, 2011 10:13 am ] |
You want to be looking for the truck length 4 speed OD I just recently swapped from the NP435 to the ODA833 and I am loving it. Basically on the truck version you have a long tail shaft that has a mounting pad near the very back and one near the very front. I know where there is one for sale in my area but the guy wants $300 for it. If you need any help or have questions I am more than happy to give you information on what you need to get everything switched over. Thanks Jeff jeff_yarbrough@hotmail.com 509-863-2617 |
| Author: | Tinker67d100 [ Mon Nov 28, 2011 8:21 pm ] |
I am starting the same swap , it looks AS if I am going to have to change my bell housing on my swap and add a crossmember |
| Author: | Rug_Trucker [ Tue Nov 29, 2011 9:21 am ] |
833OD uses a 727 front yoke. Your tranny? I don't know. |
| Author: | hantayo13 [ Tue Dec 13, 2011 4:16 pm ] |
you will need bell /clutch fork for 833OD m also |
