It is currently Tue Nov 24, 2026 4:19 am
PostPosted: Sun Nov 27, 2011 9:36 am
Will a T04E work? On ebay they are claiming it would work on the Grand National.
Also is there a link to mod a carb for blow thru?
I want to run about 10psi ,2bbl or 4bbl carb?
1970 Dodge Dart Custom w/ 1bbl slant six
PostPosted: Sun Nov 27, 2011 10:45 am
Which T04E? There are a lot of different compressor trims. Ebay claims are generally dubious
Yes, we have provided links to modifying carburetors for blow-through. You can make a 2bbl or 4bbl work just fine. User KenUSA has a 2bbl on his turbo car and did a good write-up on getting it tuned. He used a Ford turbo with a Volvo compressor wheel if I remember correctly.
PostPosted: Mon Nov 28, 2011 3:49 am
You might find a stock GN turbo used on turbobuicks.com. Some folks have had good luck with gpopshop.com too.
PostPosted: Fri Feb 17, 2012 7:29 pm
Turbobuicks is where I got mine. 150 shipped and it was complete and with an adjustable wastegate. Guy by the name of intercooled88s sold it to me. He buys gbody cars and parts them out and he got me a great condition turbo off an 87 gn. Look him up over there and send him a message im sure he can hook you up. Or list check out the parts for sale section. There's stock turbos in there fairly often. I personally went into the parts wanted and asked for a complete good running turbo that didn't need a rebuild for 150 bucks. I had several people message me. So its not hard at all to get one from there.
PostPosted: Sat Feb 18, 2012 3:18 am
Check 'bigslant6fans' post here:
http://board.moparts.org/ubbthreads/sho ... w=1#UNREAD
PostPosted: Thu Apr 12, 2012 7:56 am
check turbobuick.com
Notice it does not have the extras at the end of turbobuick.. I think the s site was for the south...
I have a stock down pipe for one of these turbos with a waste gate that is built in.. A stock setup someone can have if they pay the shipping..
Steve
37 Plymouth
62 Lancer GT
