| bypassing my points https://slantsix.org/forum/viewtopic.php?t=4717 |
| Author: | 64dodgedart [ Sun Dec 29, 2002 8:16 pm ] |
| Post subject: | bypassing my points |
My '64 dodge dart goes through points like crazy, no clue why. I was thinking about switching to an electronic ignition conversion kit. Has anyone had any success with this?? |
| Author: | Loghead [ Mon Dec 30, 2002 7:21 am ] |
| Post subject: | Dumb question, and an answer |
Going through points? Is a ballast resistor in the primary circuit? Now for the answer. Go with the electronic ignition. You might be able to get an aftermarket system or get one from a salvage yard. |
| Author: | GTS225 [ Mon Dec 30, 2002 9:23 am ] |
Is it the original distributor.........and does the shaft wobble around in the bushings? Yes, it would be wise to do the electronic conversion. I'm a cheapskate, so I would be scrounging the salvage yards for usable parts before getting an MP kit. Roger |
| Author: | Bruce Johnson [ Mon Dec 30, 2002 6:57 pm ] |
The capacitor prevents allot of arcing at the points and should be changed along with the points. I remember when I used to run points that a defective capacitor or two came with some cheeper tune up kits I bought. and of course 12v is for starting 6v is for running. A inexpensive volt /ohm meter its great for tracking down all sorts of problems. hope this helps. Bruce Johnson |
