| OK passengers side ft. motor mount https://slantsix.org/forum/viewtopic.php?t=47418 |
| Author: | USAJon [ Sat Dec 31, 2011 12:38 pm ] |
| Post subject: | OK passengers side ft. motor mount |
got the drivers side nut off the motor mount but the passengers side looks like I can't even see it. 1969 dodge dart slant six do i remove coil/fuel pump ? |
| Author: | DusterIdiot [ Sat Dec 31, 2011 6:43 pm ] |
| Post subject: | Hire a contortionist... |
Quote: but the passengers side looks like I can't even see it.
You'll have to jack the car up and pull the passenger tire to get your meaty fists in there. On my '67 it was easier to pull the 2 nuts at the bottom of the mount than try to get in there with a box end and get the one bracket nut a smidge of a turn at a time.1969 dodge dart slant six do i remove coil/fuel pump ? Just for ease of access to the area, and better cooling for the coil, most users relocate the coil and bracket to the passenger side fender. Good Luck, this one is almost as fun as swapping out the oil pump, especially if the mounts are older than dirt. -D.Idiot |
| Author: | USAJon [ Sun Jan 08, 2012 4:10 pm ] |
jacked it up pulled wheel removed plastic splash shield remove the 1 motor mount 3/4 nut removed two trans bolts removed loose exhaust motor is free/will try and get crane and pull engine/trans as a unit hopefully weather will hold as Im outside thanks! |
| Author: | DusterIdiot [ Sun Jan 08, 2012 5:40 pm ] |
| Post subject: | Cool! |
Sounds like you got it! Good luck on the pick! -D.Idiot |
