It is currently Tue Oct 13, 2026 9:19 am
PostPosted: Thu Jan 05, 2012 7:21 pm
for those with wide band gauges, any preference between
analog like the innovate 3822 and digital like the autometer 5779.
I like the look of the innovate 3822, but don't know it it will have enough resolution to be useful,, on the other hand,, on the digital units, does the last digit remain steady or does it roll?
basic question is what is most useful?
here's photos,
http://www.google.com/products/catalog? ... 9233397941#
http://www.google.com/products/catalog? ... 2209702898#
PostPosted: Thu Jan 05, 2012 7:42 pm
I have the AEM gauge with both LED sweep and numerical readout on both Darts. Love it.
PostPosted: Thu Jan 05, 2012 8:01 pm
that actually has decent asthenics,,,thanks!
http://www.aemelectronics.com/wideband- ... -gauge-25/
can it be used to to .x digit?
DT
PostPosted: Fri Jan 06, 2012 5:27 am
Yes, that's it. I believe you are asking if it gives sensible readings to the tenths place (.x digit), and the answer is yes.
PostPosted: Fri Jan 06, 2012 12:26 pm
I have the same piece Lou has, I like it :)
Kev
PostPosted: Sat Jan 07, 2012 5:56 am
Have same. A+
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Jan 07, 2012 12:06 pm
For what it is worth, the AEM gauge, which I also bought upon Lou's advice, has both analogue and digital output wires. You can go either way with it.
It has been absolutely reliable. Don't make the mistake I made of placing it too far back from the manifold. Until I moved it to a spot 18" from the turbo outlet, it would give me error messages, and not read reliably.
SAm
PostPosted: Sat Jan 07, 2012 8:01 pm
Hey,, thanks, looks like AEM just sold another one :D
PostPosted: Mon Jan 09, 2012 6:52 pm
If anyone else is buying one, I found them on eBay for $162.95
Does anyone know this seller? Is this too good to be true?
PostPosted: Mon Jan 09, 2012 7:29 pm
Yep,had a few friends buy from them. No issues.
PostPosted: Mon Jan 09, 2012 8:59 pm
Thanks, raPoM!!
PostPosted: Mon Jan 09, 2012 9:02 pm
Anytime :D After I start school,and can hopefully find a part time job,I am going to pick one of these up. Prob the best tuning tool out there.
PostPosted: Fri Jan 13, 2012 1:55 pm
Sam
concerning the readability issue
I spoke with AEM tech support,, they said the Bosch sensor is a heated unit,,
within reason, distance from the ex port should not matter,, funky readings probably indicate air in leakage...
AEM recommended gasketed flange connectors ahead of the sensor.
I have some long down tubes,, makes my install more interesting...
PostPosted: Sat Jan 14, 2012 6:07 am
OH YEAH, air leaks into the exhaust really foul up AF readings. Needs to be tightly sealed upstream of AF and I would guess for a foot or so downstream.
Users browsing this forum: Amazon [Bot] and 11 guests
