It is currently Tue May 19, 2026 9:31 am
PostPosted: Sat Jan 21, 2012 8:22 pm
My a833 is bad replacing it with another one but can't get yoke out pulled trans went redneck and chained transmission it to bumper then to motorcycle and still won't come out just won't budge!! Is it time to give up and get a new yoke??
PostPosted: Tue Feb 14, 2012 11:10 am
Drill Back Cover plug of yoke .. Install grease zerk..
Pump the yoke full of grease..
The hydraluic pressure between the yoke and the output shaft of the trans should forece the yoke off..
Heat can be helpful too in this situation.
Some thoughts..
Good Luck.
PostPosted: Tue Feb 14, 2012 11:20 am
Try the method above first...
After the yoke's cover plug pops-off, ( :wink: )...
Get a piece of barstock, that can pass thru the yoke's u-joint "eyes", drill and tap a hole into the barstock. (Fine threads work a bit easier)
You can now use a long threaded bolt to push off the exposed end of the trans' output shaft... threading-in the bolt will "push" the yoke out.
