It is currently Fri May 29, 2026 11:31 am
PostPosted: Sat Jan 28, 2012 2:37 pm
Car Model: 87 B150, 1970 Valiant 4-door
teardown was too rusty/dirty to see anything well enough to make sense of it.
I never had front drums before.
One spring that came off doesn't resemble anything in new hardware kit. No idea where it goes.
thanks.
PostPosted: Sat Jan 28, 2012 4:04 pm
This is one of a great many reasons why you really need a proper service manual.
PostPosted: Sun Jan 29, 2012 6:54 pm
Wow! :shock:
Should I be feeling "old" if I'm surprised by that statement?
63 Valiant Wagon
225 - 4 bbl
PostPosted: Mon Jan 30, 2012 5:38 am
I have a diagram from the factory service manual. PM your email address and I'll send you a PDF.
PostPosted: Mon Jan 30, 2012 8:28 am
In the future, it might behoove you to clean the item being rebuilt before disassembly and take a few pictures of the unit still assembled for reference. At least until you get a factory service manual.
PostPosted: Mon Jan 30, 2012 9:03 am
Do one side at a time!
PostPosted: Mon Jan 30, 2012 9:37 am
Thanks Slanted Opinion.
I won't need it. I figured it all out.
Mystery spring was really just a broken spring.
(One side at a time was not an option as I had to evaluate what was salvageable before making the decision to temporarily restore 9" drums, or do disk swap first. As it turned out, I got by with new drums, hardware, self adjusters, lug studs, wheel seals and wheel cylinder kits and some shop time to press/swage/cut. Had I needed much more, I'd have abandoned the drums altogether.)
Thank you everyone for your replies.
