It is currently Sat Oct 10, 2026 2:11 am
 Post subject: coil voltage
PostPosted: Sat Feb 04, 2012 7:03 pm
just changed from points to a pertronix 11. everything working good. but wondering if i need the ballast resistor any more as it's purpose is to make the points keep from burning up prematurely. i am running a 1.5 ohm coil,and know i would get a better spark without the ballast resistor, but don't want to do it at the expense of burning up the coil.
also, the pertronix came with a new rotor, but it is different than the points rotor i removed. i would like to get a spare. does anyone know what they use for a rotor in their kit?
Most of the stuff people worry about ain't never gonna happen anyway!!!
chuck Anglemyer
chucks' rod garage
PostPosted: Sat Feb 04, 2012 7:07 pm
Pertonix II doesn't need the ballast.
It is variable dwell and senses coil voltage.
You can go down to a 0.6 ohm coil if you want too.
PostPosted: Sat Feb 04, 2012 7:17 pm
they don't tell you that in the directions. they just say to take the pertronix power from the 12 volt side of the resistor. thanks for the input
chuck Anglemyer
chucks' rod garage
PostPosted: Sat Feb 04, 2012 7:19 pm
Look at the ad
http://www.pertronix.com/prod/ig/ignitor2/default.aspx
PostPosted: Sat Feb 04, 2012 9:19 pm
Yes, you need a full 12 volts to power the module electronics. To get it you bypass the resistor. No need to reduce the voltage any longer with a resistor.....the module will just run poorly.
Users browsing this forum: No registered users and 36 guests
