It is currently Tue Oct 13, 2026 8:17 am
PostPosted: Thu Feb 09, 2012 5:44 pm
i have a 71 slant with a bad balancer, outer ring came off the hub on the crank. no experience with slants. no bolt in center of crank ( should there be ?) holding it on. 1st, how do you get it off? 2nd where can i get a good one? any help would be very much appreciated
PostPosted: Thu Feb 09, 2012 5:54 pm
falcon global on ebay sells both the Romac SFI unit and also another aussie made unit that is a very nice peice...
there on ebay under slant six, or slant 6
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
Use a steering wheel/balancer puller. You can get one at any parts store, some even loan them.
No bolt is normal.
Google Damper Doctor/Damper Dudes for rebuilt dampers.
:D
PostPosted: Thu Feb 09, 2012 6:46 pm
thanks guys, checked out the balancers , the aussie one sats it fits 60 tru 84. in 76 the slant got a cast crank will this one work on my 71?? how can it work on both??
PostPosted: Thu Feb 09, 2012 6:51 pm
Site Admin
Yep. It'll work.
CJ
PostPosted: Thu Feb 09, 2012 6:54 pm
thank you
PostPosted: Thu Feb 09, 2012 7:04 pm
Site Admin
If it's for a hot rod, the Aussie one looks pretty sharp.
I have a nice SFI Damper. It weighs a ton compared to the OEM ones. Might actually have enough mass to dampen harmonics on the crank, but I doubt it. :lol:
A '71 crank is forged.
CJ
PostPosted: Thu Feb 09, 2012 7:05 pm
Make sure it has multiple timing marks. The location of the mark/tab changed in the late '60's.
