| 833 versus OD833 shifter rods https://slantsix.org/forum/viewtopic.php?t=47851 |
| Author: | 65 dartman [ Wed Feb 08, 2012 10:25 am ] |
| Post subject: | 833 versus OD833 shifter rods |
I've got a 65 833 mated to a slant. Just picked up an OD833 and bellhousing without shifter rods/swivels, etc. The cases look the same; are the shifter rods the same as well? |
| Author: | hantayo13 [ Wed Feb 08, 2012 12:17 pm ] |
only differentance is the third/forth lever on trans installed flipped so it shifts 3rd is 4th and 4th is od |
| Author: | John Brayton [ Thu Feb 09, 2012 7:27 pm ] |
| Post subject: | shifter rods |
Just installed the A833 rods into an overdrive trans. We had to lengthen the third/fourth rod one inch to make it work correctly. Regards, JB |
