It is currently Wed Sep 30, 2026 1:43 pm
PostPosted: Wed Feb 08, 2012 10:25 am
I've got a 65 833 mated to a slant. Just picked up an OD833 and bellhousing without shifter rods/swivels, etc. The cases look the same; are the shifter rods the same as well?
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Feb 08, 2012 12:17 pm
only differentance is the third/forth lever on trans installed flipped so it shifts 3rd is 4th and 4th is od
 Post subject: shifter rods
PostPosted: Thu Feb 09, 2012 7:27 pm
Just installed the A833 rods into an overdrive trans. We had to lengthen the third/fourth rod one inch to make it work correctly.
Regards,
JB
1962 Plymouth Valiant
