It is currently Sun Nov 15, 2026 8:28 am
 Post subject: what is it?
PostPosted: Tue Feb 14, 2012 5:35 pm
Car Model: 87 B150, 1970 Valiant 4-door
Imageodukator
It's a choke modulator, right?
A 1970 shouldn't have an electric choke, right?
It's hacked into an alternator field wire.
It seems to be working.
Is this a Mopar part for a later car?
Once I confirm it is working correctly, should I replace the oil pressure switch with a newer version and power it off of that?
PostPosted: Tue Feb 14, 2012 5:38 pm
Yep electric choke,either someone installed it,or installed a later engine in your car.
PostPosted: Tue Feb 14, 2012 5:40 pm
Choke controller/timer. I think they started using them around '73/4. It was wired to the alternator so if you left the key on it would not open the choke and cause a no start. :D
