| what is it? https://slantsix.org/forum/viewtopic.php?t=47911 |
| Author: | Ed Mullen [ Tue Feb 14, 2012 5:35 pm ] |
| Post subject: | what is it? |
odukatorIt's a choke modulator, right? A 1970 shouldn't have an electric choke, right? It's hacked into an alternator field wire. It seems to be working. Is this a Mopar part for a later car? Once I confirm it is working correctly, should I replace the oil pressure switch with a newer version and power it off of that? |
| Author: | raPoM [ Tue Feb 14, 2012 5:38 pm ] |
Yep electric choke,either someone installed it,or installed a later engine in your car. |
| Author: | slantzilla [ Tue Feb 14, 2012 5:40 pm ] |
Choke controller/timer. I think they started using them around '73/4. It was wired to the alternator so if you left the key on it would not open the choke and cause a no start. |
