It is currently Tue Nov 17, 2026 12:15 am
PostPosted: Fri Mar 02, 2012 6:57 pm
any one know where to find a whole rebuild kit??
thanks
jimbo
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
 Post subject: A couple places
PostPosted: Fri Mar 02, 2012 7:12 pm
It depends on what you consider a "complete kit"...
Northern Auto Parts and Performance Automotive Warehouse
Both have kits that will net you pistons, rings, rod and crank bearings a seal and gasket kit, freeze plugs, oil pump, and possibly a 'stocker' replacement camshaft and lifters.
You'll be responsible for an aftermarket cam, head work (valves,springs, etc), the oil pump pickup, and other odds and sods.
 Post subject: Re: A couple places
PostPosted: Sun Mar 04, 2012 10:01 am
As of 9/30/2010 PAW only sells early Hemi Parts.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Sun Mar 04, 2012 4:41 pm
ebay has some good deals but you have to shop different sellers for gaskets,bearings,rings.
PostPosted: Mon Mar 05, 2012 12:54 am
I was looking at the ones from Flatlander Racing, does anyone have any experience with these? (They also apparently have standard rebuild kits as well)
Thanks,
Al
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
PostPosted: Mon Mar 05, 2012 3:31 am
This is the road I have chosen. I haven't gotten around to rebuilding mine yet but I have all that I need to do except Rod and Main bearings as I don't know where my cranks at, outside of in the motor! You understand? Know what you want to do, where your motor stands now and buy componets where you can for a deal! I scored a set of .40 over pistons on the Bay for $20 3 years ago. I believe my motors untouched so I"m going with that and hope I didn't waste coin. Hope I didn't screw myself, any any rate! So far in parts I have spent around $400 for the parts for the build I want to do. As far as who to go with for a rebuild kit? I can't give you a honest answer, you'll just have to keep searching and go with what puts the most $$$$ in your pocket. BTW, for the cam I went with the Erson Cam deal at this site. Cam, lifters, Springs for around $250 is a stea in my opinionl!!!! Good Luck
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
