| Axle Seal Removal https://slantsix.org/forum/viewtopic.php?t=48124 |
| Author: | vynn3 [ Thu Mar 08, 2012 1:44 pm ] |
| Post subject: | Axle Seal Removal |
Hey guys, I seem to have misplaced my service manual... What's the proper way to remove the axle seals on an 8 3/4" housing? Do I need a special tool? |
| Author: | wjajr [ Thu Mar 08, 2012 2:29 pm ] |
I just use a pair of channel locks, or big screw driver, and pop it out. |
| Author: | vynn3 [ Thu Mar 08, 2012 2:40 pm ] |
Thanks. I'll give the channel locks a try, but it hasn't even budged yet... |
| Author: | Doc [ Thu Mar 08, 2012 2:42 pm ] |
Another "trick" is to use the axle shaft to pop the seal out. Insert the tip of the axle shaft, behind the seal and pry it out. DD |
| Author: | vynn3 [ Thu Mar 08, 2012 2:50 pm ] |
Thanks Doc, I'll try that, too! I must be over thinking this... vm |
| Author: | stop the beast [ Tue Mar 13, 2012 5:29 pm ] |
I used a small chisel to put a dent in the seal and relieve some of the pressure on the seat around the axle housing and then popped it out with the axle like Doc described. |
