It is currently Sun Nov 15, 2026 8:52 pm
PostPosted: Sun Mar 11, 2012 12:06 pm
Car Model: 87 B150, 1970 Valiant 4-door
HEI conversion right after I pass emissions this month. Lean burn has .045 gap. (HEI can do same gap, right?)
Autolites in now (didn't know re. China stuff until after they were installed 3 years ago.) Don't expect them to survive being removed and reinstalled to check condition/cleaning prior to re-inspection (high HCs).
thanks.
 Post subject: Which head?
PostPosted: Sun Mar 11, 2012 12:19 pm
If you have the stock BL plug head 1975-1987 heads the UR-5 is the stock replacement, you can run a hotter plug UR-4 if needed.
Drool Tube heads have more options at this point.
PostPosted: Sun Mar 11, 2012 6:22 pm
thanks
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
