It is currently Thu May 28, 2026 1:46 am
PostPosted: Sun Mar 18, 2012 10:23 pm
As stated in the title, I need to replace my idler arm on my '70, how involved of a job is this? I have heard it can be quite a pain, I've got a lot of slop in it, about an inch or so in any given direction.
Also, do I need to order a new arm? When I was at the parts store they had a Idler arm bushing, but I'm sure someone more qualified than myself can tell me what I need to do exactly.
Thanks,
Seth
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Wed Mar 21, 2012 9:21 am
Car Model: '64 Valiant Convertible
I think last time, I used an engine hoist to lift the motor up (after loosening the motor mounts) just a couple inches. That gave me enough room to remove the idler bolt which is installed from the top-down. Don't get any ideas about re installing it from the bottom-up, cause if you did, and the nut vibrated off, your Dart will find another ditch.
I really think the idler has failed prematurely due to A- cheap offshore junk construction, or B- aged ball joints and bushings, in which case you will be throwing money away by just replacing the idler.
Remember, I have a brand new idler with the rest of those parts for you.
Neil
PostPosted: Wed Mar 21, 2012 9:32 am
When I had the front end checked they said it seemed like a entire piece of the bushing was missing, I may just pull it apart to look at it and see what the damage is.
 Post subject: But...
PostPosted: Wed Mar 21, 2012 6:34 pm
If you're on the ball, you drill the bolt above the nut and install a hairpin
as a retainer...no matter which way the bolt is pointed...
