It is currently Tue Oct 13, 2026 10:50 pm
PostPosted: Sun Apr 01, 2012 10:09 pm
wondering what is the easiest way to remove the radeo and top dask speaker out of a 63 valiant...i been looking and im too scared to pry anything...reason being is this:
when i turn my radeo on noth i can hear a slight sound of static when i juggle the nobe sometimes or poping out of the speaker but i cant find anything on the radio no static sound nothing asides from that...radio broke? or what do u gusy think? anyoen have a working radio for sale :p?
63 Valiant 4 door
PostPosted: Sun Apr 01, 2012 10:43 pm
With my 64, remove radio to get to speaker.
Removing glove box helps with removing radio.
Don't remember all the details, but it wasn't all that hard........
PostPosted: Sun Apr 01, 2012 10:54 pm
Very easy. Disconnect battery negative. Remove glovebox door. Remove glovebox. Pull off inner and outer radio knobs. Remove left and right radio shaft nuts. Unscrew radio rear brace. Push/pull radio forward towards engine, pull forward/downward until it clears dashboard. Unplug electrical supply connection from wire and round metal antenna connector from radio body. Remove speaker wires from speaker. Remove left and right speaker bracket nuts. Lower speaker.
PostPosted: Mon Apr 02, 2012 6:21 am
hah wow they dont make em like they used to....good stuff thanks all...any imput on my problem? bad radio? bad connection?
63 Valiant 4 door
PostPosted: Mon Apr 02, 2012 9:11 am
Likely the radio is in need of repair. If you're not a do-it-yourselfer in this regard, see my reply to your other post (about updating the radio).
If you want to try to repair it yourself, the "PhotoFact" diagrams go across eBay pretty often.
Users browsing this forum: No registered users and 21 guests
