It is currently Sun Sep 13, 2026 9:45 am
PostPosted: Wed Apr 04, 2012 9:41 pm
i think my valve cover is leaking...so this weekend i would like to replace it and see if it stops my leak. there was oil everywhere s i power washed it all off and drove it arround today going to look tomorrow to confirm. my question is this.
can i use black gasket maker(silicone/RTV) sealent to seal the cover to the head?
or shud i hunt down a fel pro gasket or equal?
63 Valiant 4 door
PostPosted: Wed Apr 04, 2012 11:23 pm
You need to remove the valve cover to adjust the valves every once in awhile......
So I wouldn't be glueing it on.
I like the rubber ones, you can reuse for awhile.
Smear some white grease on it so it doesn't stick to the head.
PostPosted: Wed Apr 04, 2012 11:30 pm
There's a good chance it is.
Yes, but (1) it won't work well, and (2) you'll regret it next time you have to do a valve adjustment, and (3) it's harder than doing the job correctly with the right gasket.
PostPosted: Thu Apr 05, 2012 6:41 am
part number for rubber gasket? or is it just a felpro gasket?
63 Valiant 4 door
PostPosted: Thu Apr 05, 2012 6:45 am
Its listed int the valve adjustment thread that Dan posted, (at the bottom)
MRO....
PostPosted: Thu Apr 05, 2012 8:33 am
It's just a Fel-Pro gasket.
Since you are removing the valve cover, it would be a great time to check the lash on the valvetrain!
~THOR~
 Post subject: .
PostPosted: Thu Apr 05, 2012 11:15 am
You must use a gasket,there's very little clearance between the top of the valve cover and the rocker arms. They might hit w/o the aditional spacing the gasket provides.
Users browsing this forum: Amazon [Bot], Google [Bot] and 101 guests
