It is currently Mon Oct 26, 2026 12:12 am
PostPosted: Thu Jan 23, 2003 9:46 am
I finally got most of the leak problems with my carb fixed. She runs so smooth now. 40 psi of Oil pressure at idle around 600 rpm. I also tested the vacuum. Is 18-20" within Spec?
Thanks!
Eugene
'66 New Yorker 2dr hdtp
'73 Dart sedan 225
Check out the band! www.double-yellow.com
PostPosted: Thu Jan 23, 2003 10:20 am
Those are pretty typical numbers for a stock motor in good shape and tune.
PostPosted: Thu Jan 23, 2003 4:21 pm
About what you want to see, try giving it a little more timing advance, that may get you a bit more idle vacuum.
