It is currently Sat Jun 13, 2026 3:25 pm
 Post subject: help me find lines!
PostPosted: Sun Apr 22, 2012 9:17 pm
hey guys looking for replacement tranny lines for my 63valiant...i found 2 sites but cant pin point the ones i need...
http://finelinesinc.com/
http://www.canlinetube.ca/index.php
63 Valiant 4 door
PostPosted: Sun Apr 22, 2012 10:20 pm
As far as I know, new lines for a slant-6 Valiant can't be had. V8 lines are available prebent.
See my thoughts on the subject here, or see here if you really want to make up new hardlines, and don't forget to eliminate the external filter to save yourself a bunch of hassle; see here.
PostPosted: Mon Apr 23, 2012 6:24 am
dont think that will be a option for me....i know nothing about bending nor do i have the tools to do it.
Can i juts cut the line and replace with rubber tubing? or is there too much pressure? cant believe no one reproduces these on the forum here...id be willing to pay 100 for a set
63 Valiant 4 door
PostPosted: Mon Apr 23, 2012 8:13 am
QUICK QUESTION: i found sum straight tranny lines with fittings on the end but what size of fitting r the ones on the 63 val push button tranny?
63 Valiant 4 door
PostPosted: Mon Apr 23, 2012 11:42 am
5/16 tubing with a "tube nut" & double flare at each end.
PostPosted: Mon Apr 23, 2012 12:12 pm
good stuff...but it turns out what they have wont work...but i think its leaking from the piece of piping the previous owner put in place of the in line filter will post pics to confirm.
63 Valiant 4 door
 Post subject: .
PostPosted: Wed Apr 25, 2012 5:16 pm
You could also remove the SAE adapter fittings from the trans and radaitor and use 1/8" NPT (pipe thread) fittings.
