It is currently Sun Nov 22, 2026 12:20 am
 Post subject: Best quality parts
PostPosted: Wed Apr 25, 2012 6:41 am
Hi,
I have a 350 Holley, and I might be up for a new power valve and some jets, (possibly had wrong size installed)
Does some online store exist that has high quality parts? Or since is it a 'it'll never fail item' so it doesn't matter where I get it?
Thanks.
PostPosted: Wed Apr 25, 2012 9:35 pm
Summit Racing carries Holley brand parts. I always buy the Holley Brand and not generic.
 Post subject: .
PostPosted: Wed Apr 25, 2012 10:06 pm
A Holley power valve called "a never fail item"? You've never had one fail?Brother,I'd like to shake your hand, I always wanted to meet the luckiest man alive
PostPosted: Thu Apr 26, 2012 8:03 am
bigslant6fan - still only been at this for a few years. Got my first 350holley carb a few months ago (still fixing the car up). Doesn't rev past 3000, seems to just bottom out. I'll be looking at the valves jet sizes, ensuring it was put together correctly + vacuum leaks etc.
Might already have the faulty valve :(.
PostPosted: Fri Apr 27, 2012 12:49 am
What are the symptoms of a faulty pv?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
 Post subject: .
PostPosted: Wed May 02, 2012 3:25 pm
A blown PV will cause it to run very rich at idle. A 350 CFM carb should work well, without flat spots on a S/6. My 300 CFM carter BBD pulls strong to 5,000. Maybe you have other problems like a weak fuel pump.
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
