| start problem https://slantsix.org/forum/viewtopic.php?t=48659 |
| Author: | robert garner [ Sat Apr 28, 2012 1:33 pm ] |
| Post subject: | start problem |
83 D-150 slanted, engine started normally...died would not re-start there is only a click at the turn of the key. Replaced starter with a known good starter...just a click Replaced starter relay...just a click Need your valued input, thanks robert |
| Author: | 64 Convert [ Sat Apr 28, 2012 2:04 pm ] |
My guesses in order of probability...dirty connections at the battery...dead cell in the battery...internally corroded battery cable...loose ground connection. |
| Author: | wjajr [ Sat Apr 28, 2012 7:25 pm ] |
Yup, battery connections, ground to block should be cleaned, and the battery its self can be good one moment, and dead enough to not turn over the engine the next start. |
| Author: | Aggressive Ted [ Sat Apr 28, 2012 10:29 pm ] |
Battery cables do rot out after 30 years and will not carry enough amperage to kick the starter over..... Ask me how I know......then why it rotted out 10" from the starter.... |
| Author: | robert garner [ Sun Apr 29, 2012 7:12 am ] |
Thanks Boys, today is already car care day and I will check the connections and cables, I thought that I had pretty much covered the bases, it's the simple stuff that gets me ,at least when it's not the other stuff.I will let y'all know how it goes. robert |
