It is currently Wed Nov 25, 2026 11:32 pm
PostPosted: Sat May 19, 2012 5:18 am
I tried setting the timing today to 2.5 deg BTDC as per factory but the mark was running all over I.e. Very unstable. I set the thing the best I can and took a long drive, after about 50 miles of driving the engine start pinking badly at anything above 1/3 throttle. I suspect the timing went crazy and advanced by itself.
What could cause this? The spring inside the distributor? Is it hard to take the distributor out?
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Sat May 19, 2012 5:53 am
Timing chain/gears need replaced. Worn out. Dennis
PostPosted: Sat May 19, 2012 6:12 am
I've got brand new chain and new harmonic damper. So I don't think its the chain.
PostPosted: Sat May 19, 2012 7:20 am
Your points need sharpening (replacing).
Its easy to get the distributor out.....
Some people have problems putting it back.
PostPosted: Sat May 19, 2012 8:51 am
While the distributor is out, clean and lubricate the mechanical advance mechanism. The 40 year old grease on the advance weights and guide plate can harden and get sticky and can make the mechanical advance mechanism stick and not operate smoothly.
PostPosted: Sun May 20, 2012 7:00 am
Car Model: '63 Dart GT Convertible
Do yourself a favor, get rid of the points, get Pertronix. Easy to install, looks stock, don't gotta jack with it. I might have one around here from my brothers car if you are interested.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Sun May 27, 2012 10:30 am
I had the same problem. I checked the distributor shaft for play and found the bushings were sloppy.
1968 Plymouth Barracuda Convertible Super six
Users browsing this forum: Amazon [Bot], Bing [Bot] and 8 guests
