It is currently Sun Jun 21, 2026 3:51 pm
PostPosted: Sun May 20, 2012 3:33 pm
I have a 66 barracuda and every darn time I fill up with gas, the gas shoots out of the fill hole all over the car, me, and the gas station. Can anyone clue me in, please? Is this just the way these things were made and it is not amenable to modern pumps, or is there something wrong with my vehicle?
Eugene
PostPosted: Sun May 20, 2012 4:30 pm
They all do it. It can be reduced with some fairly easy modification work to the fill pipe (installation of a restrictor plate). See here, here, and here.
(Also, there's no need to "shout" your question by using big, bold type. We hear you just fine with regular normal type, please and thank you.)
PostPosted: Sun May 20, 2012 9:48 pm
it takes a lot longer to fill with gas, but my dart does fine if i put the pump on the first "click" setting for slow pump, but fixing the problem is better.
-Christopher
"Gray Ghost"-1970 Dart.
"Frederick II"-1994 Geo Metro.
PostPosted: Mon May 21, 2012 11:37 am
I never "Fill-up" and early A-body...
I just figure-out how much the car will take, to get to 7/8 of a tank, max... and put that much $$ on the pump. That way, the pump slows & stops before "spitting back".
PostPosted: Mon May 21, 2012 11:47 am
Well I never have enough money to get it THAT full... :lol: 20-30 bucks is about it for my monthly allotment... :lol: Course my car is an F and it does spew, dribble, run down the quarter panel even on slow setting unless i turn nozzle just right...
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Mon May 21, 2012 12:46 pm
I always fill my tanks full. This is the ONLY way to get a reliable gas mileage measurement, which I do on every tank.
Here's what I do:
1) Estimate how much the tank will take based on the gas gauge (say 12 gals if the gauge says 1/4 tank).
2) Put nozzle into filler neck with a fairly large cloth rag held between the bottom half of the pump pipe/shroud and the car body and filler neck. Hold the pump nozzle in firmly and push the nose of it down as much as possible. The rag should stay there for the whole time of pumping.
3) Put the pump on the highest setting for 3/4 of that amount (say 9 gals).
4) Move pump to lowest setting and hold firmly in, as in step 2.
5) Gas will come up the neck and hit the rag and not spill out. Usually I can do this without dribbling on the paint.
You will hear the gas coming up the neck if you get your ear within about 1-2 ft of the filler neck opening, and you can sometimes stop it before the fuel reaches the rag.
On my '66-down cars, I hold the nozzle in for the whole time (steps 2 on). On my '68 Dart, I can leave it there w/o the rag and wash windows or check oil until it gets to the end of step (3) above, at which point, I hold it in and go on with step (4).
PostPosted: Mon May 21, 2012 1:36 pm
In Oregon, I can't fill my own car, so I just don't worry about it! :D
My paint isn't nice anyways.. :shock:
~THOR~
PostPosted: Mon May 21, 2012 3:06 pm
I have to fill my car up because the gas gauge doesn't work.....
(fill it ever 200 miles ..)
Here's my fix
http://www.slantsix.org/forum/viewtopic.php?t=40968
