It is currently Mon Nov 16, 2026 9:55 pm
PostPosted: Sun May 27, 2012 8:26 am
The previous owner did an extremely questionable 4 speed swap on my d100 pickup. I don't even want to think about the horrors lurking between the trans and flywheel. The tailshaft bushing is wore out but before I start messing with new bushings and yokes I want to be sure I have the right length driveshaft, it looks like there is quite a bit of slipyoke hanging out of the transmission. What are the relative overall lengths (longshaft) of the a833 of and common three speeds? Thanks!
Decrepit 1976 d100 undergoing a rolling restoration.
Last edited by Madmaxmechanic on Sun May 27, 2012 10:04 am, edited 1 time in total.
PostPosted: Sun May 27, 2012 8:49 am
Some ID info here:
http://slantsix.org/articles/4-speeds/O ... speed1.htm
PostPosted: Sun May 27, 2012 10:18 am
The only mention of driveshafts there was that swapping to the 833od required shortening of the driveshaft 3". Possibly the p.o used a donor driveshaft that was too short. There is 3+ inches of slip yoke extending out of the tail housing I feel like this is way too much.
