| head gasket just done.....still smokes :( https://slantsix.org/forum/viewtopic.php?t=48917 |
| Author: | 4x4jimbo [ Mon May 28, 2012 2:01 am ] |
| Post subject: | head gasket just done.....still smokes :( |
hello.i have a serious problem. i just did my head gasket on my 84 van ,it has the 225 slant 6. the cause of me doing this is ,pouring white/gray smoke.i just finished ,i changed the oil, i drove it around a little .and it is still pouring white/gray smoke.looks like the cheech n chong van coming down the road JIMBO |
| Author: | Brussell [ Mon May 28, 2012 3:02 am ] |
Valve issues? Did you do a compression check at all? Or Is it running very rich? Does your car have a cat converter? Other people with more knowledge than me will chime in I'm sure. |
| Author: | wjajr [ Mon May 28, 2012 6:11 am ] |
Sounds like a possible cracked head. Dose the bong vapors smell sweet and of antifreeze? |
| Author: | 4x4jimbo [ Mon May 28, 2012 11:21 am ] |
i think im set on a cracked head.just went and started it up. let it run.smoke gets worse as it gets hotter.whitish gray with a little blue and a very sweet smell. jimbo |
| Author: | slantzilla [ Mon May 28, 2012 2:48 pm ] |
How much have you driven it? If the exhaust is full of oil/coolant it will take it awhile to burn out. |
| Author: | mrhollywood [ Mon May 28, 2012 4:34 pm ] |
Check your compression. Could be your piston rings. How do your valve seals look...if they're hard they could be leaking. |
