It is currently Wed Nov 25, 2026 8:01 pm
PostPosted: Mon May 28, 2012 2:01 am
hello.i have a serious problem. i just did my head gasket on my 84 van ,it has the 225 slant 6. the cause of me doing this is ,pouring white/gray smoke.i just finished ,i changed the oil, i drove it around a little .and it is still pouring white/gray smoke.looks like the cheech n chong van coming down the road 8) .lol .what else would be causing it to pour smoke??????? HELP!
JIMBO
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Mon May 28, 2012 3:02 am
Valve issues? Did you do a compression check at all?
Or
Is it running very rich? Does your car have a cat converter?
Other people with more knowledge than me will chime in I'm sure.
PostPosted: Mon May 28, 2012 6:11 am
Sounds like a possible cracked head. Dose the bong vapors smell sweet and of antifreeze?
PostPosted: Mon May 28, 2012 11:21 am
i think im set on a cracked head.just went and started it up. let it run.smoke gets worse as it gets hotter.whitish gray with a little blue and a very sweet smell. :( :( :( no more mudd for a little
jimbo
PostPosted: Mon May 28, 2012 2:48 pm
How much have you driven it? If the exhaust is full of oil/coolant it will take it awhile to burn out. :shock:
PostPosted: Mon May 28, 2012 4:34 pm
Check your compression. Could be your piston rings. How do your valve seals look...if they're hard they could be leaking.
1970 Dodge Dart Custom w/ 1bbl slant six
