It is currently Thu Nov 26, 2026 7:18 am
PostPosted: Sat Jun 02, 2012 5:46 pm
Just bought a 225 lifted out of a 70 Dart
Serial on block is FW225R 3234 0198
It also has a number OR-06331 stamped on the pad at the back of the motor.
What would the W signify that is different about this engine from one built to specs?
PostPosted: Sat Jun 02, 2012 7:14 pm
F: 1970 model year engine
W: Built at Windsor Engine Plant
225: Engine displacement
R: Passenger car engine
3234: Build date 5 June 1970
0198: 198th engine built on that date
PostPosted: Sun Jun 03, 2012 4:02 am
Thanks for the prompt response
....Don
Users browsing this forum: Google [Bot] and 6 guests
