It is currently Mon Nov 16, 2026 10:05 am
 Post subject: 76 Aspen tumbler removal
PostPosted: Tue Jul 03, 2012 7:58 am
I need to get my ignition tumbler out of the column as I have lost my keys, but have no idea how to do it. Can anyone give me the ins and outs of removing it?
Some people are like Slinkies, not really good for anything but they bring a smile to your face when pushed down the stairs.
PostPosted: Thu Jul 05, 2012 6:47 am
is it a tilt collumn?
If it is, IIrc, you can use these instructions, as they are gm-saginaw parts.
clickything
I have no idea what I am talking about.
PostPosted: Thu Jul 05, 2012 11:15 am
A key can easily be made using the impression method with the ignition lock in place. Any locksmith can perform this task with a service call to the vehicle if you are so inclined…$$$$
However, remove a door lock cylinder, preferably the passenger side, drop it off at a lock smith shop, and he can quickly make a key that will fit the ignition “IFâ€￾ the door key still is the same as the ignition.
Note: Car was built with same key operating doors & Ignition, often if driver’s side lock has been changed, the passenger’s side may not have been changed as it is so seldom used and never wears out.
PostPosted: Thu Jul 05, 2012 11:19 am
GM ignition lock removal, and replacement is a somewhat different and more involved than Chrysler cylinder R&R.
PostPosted: Thu Jul 05, 2012 12:53 pm
Thanks for the tips guys! I got the procedure out of a haynes manual sent to me, and it's very simple. A new one through my work is only 18 bucks with keys, but I'd still need to do something about the door locks. Still might call the locksmith.
PostPosted: Fri Jul 06, 2012 5:56 am
I bet if you drop off a door lock to a locksmith, he will make a key for around 18 bucks that will work both doors, and the ignition, and all you have to do is pull a door panel. If you want to refresh the driver’s side door lock, the one that gets 99.9% of the use, he can do that as well for a few more bucks.
20 years ago when I had a locksmith shop, I would charge 6 bucks for the first key by code, impression, or measuring pins, and a buck for a copy. Chrysler door locks took less than five minutes to make a key from the lock on the bench…
By the way, I would rather take apart three GM steering columns to replace a cylinder, than one Chrysler ignition cylinder all day long. In fact the only time I needed to dig into a Chrysler column was for a repining, or a rare replacement of dysfunctional cylinder. My preferred method of generating a replacement for lost keys on a Chrysler was to impression one from a door lock. That procedure generally took only 10- 20 minutes depending on condition of lock, and involved no disassembly of customer’s automobile; which is always a good thing.
PostPosted: Fri Jul 06, 2012 8:00 am
You make very valid points! I think I just might pop the door lock out as I'm heading to the city this weekend anyway. I'd feel like a total ass if I buggered something up in the column.
