76 Aspen tumbler removal
https://slantsix.org/forum/viewtopic.php?t=49189
Author:  AbAspen [ Tue Jul 03, 2012 7:58 am ]
Post subject:  76 Aspen tumbler removal
I need to get my ignition tumbler out of the column as I have lost my keys, but have no idea how to do it. Can anyone give me the ins and outs of removing it?
Author:  Rust collector [ Thu Jul 05, 2012 6:47 am ]
is it a tilt collumn?
If it is, IIrc, you can use these instructions, as they are gm-saginaw parts.
clickything
Author:  wjajr [ Thu Jul 05, 2012 11:15 am ]
A key can easily be made using the impression method with the ignition lock in place. Any locksmith can perform this task with a service call to the vehicle if you are so inclined…$$$$
However, remove a door lock cylinder, preferably the passenger side, drop it off at a lock smith shop, and he can quickly make a key that will fit the ignition “IFâ€￾ the door key still is the same as the ignition.
Note: Car was built with same key operating doors & Ignition, often if driver’s side lock has been changed, the passenger’s side may not have been changed as it is so seldom used and never wears out.
Author:  wjajr [ Thu Jul 05, 2012 11:19 am ]
GM ignition lock removal, and replacement is a somewhat different and more involved than Chrysler cylinder R&R.
Author:  AbAspen [ Thu Jul 05, 2012 12:53 pm ]
Thanks for the tips guys! I got the procedure out of a haynes manual sent to me, and it's very simple. A new one through my work is only 18 bucks with keys, but I'd still need to do something about the door locks. Still might call the locksmith.
Author:  wjajr [ Fri Jul 06, 2012 5:56 am ]
I bet if you drop off a door lock to a locksmith, he will make a key for around 18 bucks that will work both doors, and the ignition, and all you have to do is pull a door panel. If you want to refresh the driver’s side door lock, the one that gets 99.9% of the use, he can do that as well for a few more bucks.
20 years ago when I had a locksmith shop, I would charge 6 bucks for the first key by code, impression, or measuring pins, and a buck for a copy. Chrysler door locks took less than five minutes to make a key from the lock on the bench…
By the way, I would rather take apart three GM steering columns to replace a cylinder, than one Chrysler ignition cylinder all day long. In fact the only time I needed to dig into a Chrysler column was for a repining, or a rare replacement of dysfunctional cylinder. My preferred method of generating a replacement for lost keys on a Chrysler was to impression one from a door lock. That procedure generally took only 10- 20 minutes depending on condition of lock, and involved no disassembly of customer’s automobile; which is always a good thing.
Author:  AbAspen [ Fri Jul 06, 2012 8:00 am ]
You make very valid points! I think I just might pop the door lock out as I'm heading to the city this weekend anyway. I'd feel like a total ass if I buggered something up in the column.
