It is currently Sun Nov 15, 2026 9:01 pm
 Post subject: Axle Gear Oil
PostPosted: Wed Jul 11, 2012 8:25 am
I've been working on making sure that I am up-to-date with the scheduled maintenance on my 65 Barracuda. Since I installed a 7-1/4 axle from a 74 Duster, I thought I should put some fresh gear oil in the axle. My 1965 owner's manual recommends API GL-4 while my 1975 FSM recommends API GL-5. I am thinking about using a 75W-90 GL-5 oil in my axle with a new Felpro RDS12775 gasket.
Robert Michell suggests in his book "Which Oil?" that GL-5 may be unsuitable for some applications. He writes the following:
To give the EP [extreme pressure] performance, most GL-5 lubricants use compounds that contain sulphur and sulphur is chemically very aggressive to what are sometimes called the "yellow metals". These nonferrous metals include copper and alloys of copper, such as bronze. ... The visual appearance of such chemical attack can vary from glazing to corrosion or pitting of the metals concerned.
Has anyone had any issues with using an API GL-5 hypoid gear oil in their axles?
PostPosted: Wed Jul 11, 2012 12:17 pm
No yellow metals in the rear end so GL-5 is fine. Good even. Yellow metals include transmission syncronizer rings and GL-5 can eat them in certain circumstances. Usually the largest problem with GL-5 in a manual trans is slow/difficult shifting. Rear axles have no such issues.
