It is currently Sun Nov 29, 2026 12:12 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Dec 10, 2010 10:50 am
Working on a long con rod SL6, using the Wiseco / K1 parts. (3.504 bore)
The piston & rods just went together and we are "fitting" the rings now. (end gap check and file & recheck...)
Here are some photos of our parts... nice stuff, even befroe we did the special prep work.
PostPosted: Fri Dec 10, 2010 2:00 pm
That's perty! :lol:
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Dec 10, 2010 5:21 pm
Ya drilled holes in the bottom ring land?????
PostPosted: Fri Dec 10, 2010 5:50 pm
Looks like he only chamfered the ones in the middle.
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Dec 10, 2010 6:26 pm
We did chamfer the two middle oil return holes... only on the "downhill" side.
But there is something else...
PostPosted: Fri Dec 10, 2010 6:28 pm
Doc,
Those pics bring back memories of a year ago when I was Putting Ruster's engine together.
are you using cast crank K1 rods or forged crank?
What valve size do you intend on running?? I am sure you are aware anything over~1.48 / /1.70 might crate some piston to valve interference as Guzzi Mark and I found out last winter / spring........
Also please enlighten us on the Oil ring supply holes / Chamfers.
Thanks for your time,
PostPosted: Fri Dec 10, 2010 6:32 pm
Ya cut some off the top of piston,,ya got dirty fingernails???
PostPosted: Fri Dec 10, 2010 6:38 pm
Looks like .30 off the tops,,,from a year ago memory.
PostPosted: Fri Dec 10, 2010 6:47 pm
Going to revise that to 100 thousands cut off the pistons.
PostPosted: Fri Dec 10, 2010 7:27 pm
I like the ringed wrist pin instead of pressed and the skirt coating is nice too.
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Fri Dec 10, 2010 8:02 pm
...Also please enlighten us on the oil return ring supply holes / Chamfers.
Seeing that we drilled oil "spit" holes into the K1 rods, pointed up & into the pistons, we want to quickly return oil off the lower cylinder wall... so we added chamfer to those lower / inner oil return holes.
And yes... we have a winner...
The piston tops have been cut-down .140
We now have a true "zero deck" engine with this one.
PostPosted: Fri Dec 10, 2010 8:27 pm
That was $100.00 to the winner right?
PostPosted: Sat Dec 11, 2010 7:14 am
Hope you don't melt those shiny new pistons - NA only? 0.140" off is a lot.
PostPosted: Sat Dec 11, 2010 9:08 am
The plan is to start-off this motor in N/A configuration with 11 to 1 static CR and go from there... a small shot of spray would be the next step, then more CR if it "lives".
I am most concerned about breaking the top ring land...
I found a "before" photo of this piston, (thanks MS Matt)
The valve notches are now 3 cc's
PostPosted: Sat Dec 11, 2010 10:08 am
Slinging too much oil on the cylinder wall may cause intake charge dilution with a low octane fuel. OIL!
