It is currently Sun Nov 15, 2026 11:14 am
 Post subject: Differential bolts
PostPosted: Fri Jul 13, 2012 6:46 pm
I am looking for the bolts that hold the ring gear to the carrier. (This is for a 7 1/4 rear)
I bought a set about 20 years ago, part number 04131255. IIRC, this part number also works on a first generation Durango.
I went to my Dodge dealer to get another set. They said the current part number is 1-04443158. I ordered a set but the bolts look different.
The original bolts have a low-profile head - like flywheel bolts. The new set has a much taller head. There is not a lot of clearance inside the rear so I am not sure if the new set will work.
Before I remove the cover and drain the diff, does anyone know if the new-style bolt will work in my rear?
PostPosted: Fri Jul 13, 2012 7:43 pm
Cant answer the direct question but if you have a decent belt sander ya might shorten the head height that way...(going slow of course, to not build a lot of heat) But maybe someone else will have a definitive answer for you.
MRO....
