It is currently Sun May 17, 2026 10:38 pm
PostPosted: Wed Jul 18, 2012 8:16 pm
Car Model: 1963 Dodge Dart convertible
I have been looking at wires from Magnecor dont seem I need the 8.5mm so was thinking 8.0mm so got a part number from Magnecor catalog:
8.0mm 7.0mm 8.5mm
1986-1979 225 engine 6022 6722 6522
1978-1975 All 6008 6708 6508
1974-1960 All refer
not sure what the refer is about but looking at the 6008 on Amazon it says for all slant sixs. However I am converting to the HEI recommendation and the standard HEI coil has a male post for the high tension side.
Does anyone know a way to get these premade lines with the coil wire set having a male end for the distributor and a female end for the tension coil output?
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Thu Jul 19, 2012 5:49 am
I am thinking next time I get wires I want to go with Firecore50's.
PostPosted: Thu Jul 19, 2012 9:17 am
Call Magnecor and explain what you're doing and they'll make you a custom coil-to-cap wire.
PostPosted: Fri Jul 20, 2012 9:25 am
Thanks Dan, knew you would get to it sooner or later!
Cheers.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
