| Spark plug wires for slant six mod to HEI https://slantsix.org/forum/viewtopic.php?t=49344 |
| Author: | hideogumperjr [ Wed Jul 18, 2012 8:16 pm ] |
| Post subject: | Spark plug wires for slant six mod to HEI |
I have been looking at wires from Magnecor dont seem I need the 8.5mm so was thinking 8.0mm so got a part number from Magnecor catalog: 8.0mm 7.0mm 8.5mm 1986-1979 225 engine 6022 6722 6522 1978-1975 All 6008 6708 6508 1974-1960 All refer not sure what the refer is about but looking at the 6008 on Amazon it says for all slant sixs. However I am converting to the HEI recommendation and the standard HEI coil has a male post for the high tension side. Does anyone know a way to get these premade lines with the coil wire set having a male end for the distributor and a female end for the tension coil output? Thanks |
| Author: | Rug_Trucker [ Thu Jul 19, 2012 5:49 am ] |
I am thinking next time I get wires I want to go with Firecore50's. |
| Author: | SlantSixDan [ Thu Jul 19, 2012 9:17 am ] |
Call Magnecor and explain what you're doing and they'll make you a custom coil-to-cap wire. |
| Author: | hideogumperjr [ Fri Jul 20, 2012 9:25 am ] |
Thanks Dan, knew you would get to it sooner or later! Cheers. |
