It is currently Wed Jul 15, 2026 2:39 am
PostPosted: Thu Jul 19, 2012 10:20 pm
I was wanting to install a autometer temp guage with a thermal couple and was wondering where or if any members have Installed one in there slant pics would be every helpful
Thanks. Org [/quote]
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Fri Jul 20, 2012 4:03 pm
I will look for pics if I have any, I drilled and tapped the head at the thermostat area to install the probe.
PostPosted: Fri Jul 20, 2012 4:07 pm
I usually install the fitting in the thermostat cover.
Off-set it to the outlet side to avoid contact with the "peak" of the thermostat, under the cover.
PostPosted: Sun Jul 22, 2012 1:13 am
Doc did you just drill and tap the thermostat housing or did you have to brazen it I like the idea it seems simple enuff
Thanks any more options
Aaron
PostPosted: Sun Jul 22, 2012 4:21 am
I installed one on my race engine using the old heater hose nipple on the head. I removed the heater hose nipple and installed the adapter to the thermocouple that leads to the mechanical gauge.
Here are a few shots - Scroll Down to Post Named 3-30-10 Engine in and Runing!
If you still use the heater on your car a pipe T could work for this..
PostPosted: Sun Jul 22, 2012 8:13 am
Greg that's a great idea thanks I already have a couple tees and some ball valves for my heater hoses too the water inlet on my Clifford intake
I don't no why I didn't think about it
Thanks everybody
Aaron
PostPosted: Sun Jul 22, 2012 12:25 pm
I teed into the Heater hose at the engine
