It is currently Mon Nov 30, 2026 2:39 am
 Post subject: Fan clutch for early-A
PostPosted: Tue Jul 17, 2012 1:33 pm
Contributor
I've been searching, but the search function isn't working properly for me again.
I recall reading on some forum about using a Jaguar fan clutch on an early-A with radiator clearance issues, and that it was a bolt-in to both the water pump and a Mopar fan.
I think someone also used a Mercedes clutch, but the fan mounting hole pattern was different.
Can someone re-enlighten me?
PostPosted: Tue Jul 17, 2012 1:58 pm
Can't help but would like the info as well.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Jul 17, 2012 2:35 pm
Contributor
Might as well ask another question.........
Has anyone installed an 18" fan on an early-A? It looks like it will clear, but maybe I'm missing something.
PostPosted: Tue Jul 17, 2012 2:42 pm
None of the regular American-type clutch fans will work. Mercedes or Toyota parts are required to have a shot at fit, and even then it's not guaranteed. Previous threads here, here, here, here.
PostPosted: Thu Jul 19, 2012 9:14 pm
i have a clutch fan from a 1977 Merecedes Benz 280SE as discussed in the first thread that dan linked. if you want it, it'll be $15 plus shipping. i paid $15 for it at the pick a part and it took some time to pull it, since the ignition was left open and the motor kept spinning for each bolt i tried to loosen. finally had to pry a pipe that i keep in my toolbox between the alternator and fan blade. i did not use it because i already dumped in a aluminum radiator and have the AC 6 (or 7?) blade fan. seemed overkill to me.
70 Plymouth Valiant 4dr
PostPosted: Fri Jul 20, 2012 2:35 am
If the original poster doesn't want it, I'll take it....
no shipping as I'm next to LAX....
PostPosted: Sat Jul 21, 2012 10:56 am
i haven't heard from him. i'll give him a week, see what develops. if not than it's yours man!
hey emsvitil, you go to spring fling?
PostPosted: Sat Jul 21, 2012 2:19 pm
No, I always hear when it was after the fact......
PostPosted: Sat Jul 21, 2012 7:08 pm
I believe "Fall Fling" is sometime in October
there needs to be someone out there representing Slant Six! There was a cruise in at bobs big boys after. that was fun.
http://www.cpwclub.com/fallevents/content/
PostPosted: Sun Jul 22, 2012 4:22 am
Contributor
Sorry for not responding. Just like I often can't search old posts, the new post search function usually fails. I don't understand why I'm having this problem with my computers when nobody else is.
Thanks for the offer, but I'm going to do some further research before I decide what to do. I found the Jaguar clutch info on another Mopar forum and want to check that out too.
PostPosted: Thu Jul 26, 2012 9:21 am
Contributor
Do you happen to know its length? The post on the other forum lists the Jaguar XJ-6 part as being 2-1/2", but I couldn't find a Hayden drawing to verify that dimension. A call to their catalog sales was fruitless, and I was unable to work through their automated system to find an engineer.
There is 2-3/4" clearance between the new aluminum radiator and the water pump, so the Jaguar unit would be a tight fit. However, the Hayden Jaguar part, made in the USA is only $35 new at rockauto.com, so if it had to be replaced it would be a bit more palatable than the foreign sourced MB part at $107. If the MB part would give more clearance, the potential replacement cost wouldn't be much of an issue.
PostPosted: Thu Jul 26, 2012 11:08 am
Its 2 3/4 from hub to front
