It is currently Thu Oct 08, 2026 9:48 am
PostPosted: Fri Aug 03, 2012 12:09 pm
I need help getting my parts together.
I have set of Dutra Duals and an Offy 4 barrel coming in the mail
Will i need a block off plate for the hotbox on the exhaust manifold? Doesn't look like they bolt together as do the super six manifolds
If i do need a block off plate, how thick can i go? there's an 1/8" thick one on ebay.
thanks so much.
God Bless
Keni
www.kenithomas.com
isaiah6:8
www.kenithomas.com
PostPosted: Fri Aug 03, 2012 1:25 pm
which rear manifold???? stock cut one will need gasket ...custom doug dutra one does not use it
PostPosted: Fri Aug 03, 2012 1:31 pm
If the set of Dutra manifolds is the type that has a modified factory manifoldto use as the rear section, then it should all bolt together like a factory set-up.
If it's "Dual Dutra Duals" (two new Dutra castings) then there is no intake heat opening so nothing needs to be blocked-off.
PostPosted: Fri Aug 03, 2012 9:27 pm
OHHH! thanks Doug. That makes sense now. Yes mine is a modified manifold i did myself. Cut it in half and welded the cut shut. i did not close up the exhaust manifold at the hot box. Wasnt aware that yours did that. Thank you for the clarification. i have learned
God Bless
Keni
isaiah6:8
www.kenithomas.com
Users browsing this forum: No registered users and 20 guests
