It is currently Sun Nov 15, 2026 2:02 pm
 Post subject: Transmission mount
PostPosted: Sat Aug 11, 2012 11:20 am
I have a 63 Dodge Polara with a 225 and a 727 trans.Ordered one thru
Napa and it was wrong. I dont know if the people before me modified
or what. The plate which mounts to trans the 2 bolt holes are 4" apart
then it drops down getting sandwiched into the rubber and 2 studs that
are 1" 1/8th apart which attaches to the bracket that bolts to frame.The bracket gets attached to frame with 4 bolts 3/4" . Is there somewhere
I could go to cross reference it ?
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Sat Aug 11, 2012 11:33 am
Your transmission is almost certainly a 904, not a 727. Mount you need is here in "never have to replace it again" polyurethane. Part number PMEB.
PostPosted: Sun Aug 12, 2012 7:58 am
Once again your info is like gold Thanks Dan
PostPosted: Sun Aug 12, 2012 12:54 pm
Glad to help out!
