It is currently Thu Nov 26, 2026 3:32 am
 Post subject: Rocker Arm Movement
PostPosted: Sun Aug 26, 2012 4:35 pm
So today I adjusted the valves on my Slant - my first time. Not too bad, it took some getting used to trying to put the socket on the adjuster while the motor was running, but I did it. Also, I think I inhaled a bunch of motor oil smoke - Cough Cough Cough.
Anyhow, I noticed that some of the rocker arms were able to slide back and forth on the shaft - left and right play. Is this normal?
Harry
1975 Plymouth Scamp 225/904/8.75
1968 Plymouth Road Runner 383/727/8.75
 Post subject: Yep...
PostPosted: Sun Aug 26, 2012 4:45 pm
Yep, there is a little 'side play' on a stock set.... If you have a lot of it (3/16"?)...then you might grab a couple spare rocker shafts at the local junkyard and 'mix and match' a tighter set (and if really persnickety...you can use a caliper to measure the length of the rocker arms to better match the lengths better if looking for a more uniform ratio...)
PostPosted: Tue Aug 28, 2012 6:27 am
I had the same issue on my slant (it was kinda bad in some spots). I used small block Chrysler rocker arm shims in different thicknesses to adjust mine. Works good if you want to go that route.
'68signet
"Living analog in the digital age."
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
