It is currently Sat Jun 13, 2026 8:32 pm
PostPosted: Thu Sep 13, 2012 1:49 pm
I am making a meaningful effort to finish the bodywork on my brother's Duster this year, and possibly even this month. I am at the stage of having to apply body filler and fiberglass to repair dents and holes, but all I have on hand are products I purchased several years ago.
I know the stuff that has been opened is unusable, but what about the filler and fiberglas materials that have just sat on a shelf unopened? Is it safe to use those?
Thanks from an autobody neophyte.
PostPosted: Thu Sep 13, 2012 3:17 pm
Bondo tends to dry-out over time and that makes it harder to mix and apply. Most body shops have a can of bondo "honey" that they can use to "thin-out" bondo.
Fiberglass resin will crystalize and the hardener "degrades" over time.
Crystilzed resin can be "repaired" by heating the container in hot water.
Degraded hardener will turn to a darker color and it will take longer to set / harden. ( it may not even harden completly)
The simple thing to do... mix and apply some samples and see if the material mixes, applys and sets-up the way you like & need it to.
PostPosted: Thu Sep 13, 2012 3:23 pm
Thanks Doc. I'll give it a try.
