It is currently Fri Oct 09, 2026 4:19 am
 Post subject: Carter B&B ID
PostPosted: Mon Sep 17, 2012 5:26 am
All
I got a Carter Ball and Ball carb and I can't find the ccrb number to order a rebuilt kit. Here are the numbers I could find on the carb:
On the side of the barrel 6 1697
On the top of the bottom plate 1-1746
On the bottom of the carb 1-1707
There is no tag on the carb.
thanks
Bearwolf63
'63 Valiant
PostPosted: Mon Sep 17, 2012 7:37 am
None of these numbers will ID the carb; they're casting numbers, and those castings were used on many different carbs. Post some clear, sharp photos from multiple angles.
Users browsing this forum: Amazon [Bot], Google [Bot] and 17 guests
